5.7 vortec with t56 transmission
Old Apr 26, 2013 | 05:54 PM
jacobd32's Avatar
Car: 1984 camaro z28
Engine: 305 for now
Transmission: t5 for now
hey guys this is my first time posting but got a few questions. after rattling it around I think im wanting to swap a a 5.7 vortec with a t56 tranny into my 84 z28 its got the stock 305 and t5 5speed now so im expecting a pretty easy swap other than tranny crossmember. my questions are will my motor mounts work, do I need to change oil pan? and what all to convert to carb. also lookin for opinions on the swap. thanks in advance
Old Apr 26, 2013 | 06:39 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 5.7 vortec with t56 transmission
the engine mounts you have will bolt right to the vortech block. the t-56 swap has been beaten to death at this point with threads on exactly how to do it and what is needed.
the carb conversion has also been beaten to death on here. but the short/simple list of things youll need is:
a carb intake for the vortech engine
a carb
an hei distributor
a return style fuel regulator if your car was originally fuel injected
appropriate linkages/throttle cables
an inspection station in an area that loosely enforces smog laws
Old Apr 26, 2013 | 06:41 PM
Yup; identical the same
A truck pan won't fit; you'll need a pan from a 86-up F body.
The motor, needs an intake, dist, and carb. The car, depends on what's in it now.
Old Apr 26, 2013 | 06:59 PM
jacobd32's Avatar
Engine: 305 for now
cool thanks guys motor mounts was the main concern
AussiePr0nCar
Mar 6, 2020 04:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
angel2794
Sep 8, 2015 06:22 PM
z28addict8490
Sep 5, 2015 03:56 PM
jharrison5
Aug 19, 2015 05:53 PM
