Formula 400
Old Apr 28, 2013 | 12:17 PM
spawnicus's Avatar
Car: 1987 firebird formula
Engine: none
Formula 400
i have an 87 formula w/ a little 305, and a 700R4 tranny i just picked up a SBC 400 for it it came out of a 79 C30 i havent seen too much on people doing this, and i dont think it's going to be too much of a problem, everything seems to be the same size, even the oil pan, which i was surprised.
but i was wondering if anyone had any tips or tricks, or know of anyproblems i may run into trying to do this, any helpful advice would be greatly appreciated
Old Apr 28, 2013 | 12:22 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
Re: Formula 400
I had an 87 350 formula I put a 406 in, (.030 over 400) that ran 12.20's and got 23 mpg on the highway.... was a blast to drive. use a smaller cam than you think you need... I ran a .214/.224 duration @ .050 and it worked wonderful. I made my own exhaust, but had cheapie headman headers with no air injection. I ran a hypertec chip [yuk] there are WAY better options out there now.... enjoy !!!! gotta have the external balanced flywheel and harmonic balancer unless you choose to buy a crank that's internally balanced...
Old Apr 28, 2013 | 12:28 PM
spawnicus's Avatar
Engine: none
Re: Formula 400
i already have headers on my 305, and supposedly this 400 already has a cam in it (but who knows?, and i'm not opening it just to find out haha) and i am keeping the externally balanced component, but did you have any problems doing the swap?, and did you use the 400 fan? because i'd like to use that one and get rid of this little electronic fan in mine
Old Apr 28, 2013 | 12:31 PM
spawnicus's Avatar
Engine: none
Re: Formula 400
it does have an edelbrock performer on it, and i have a 625 street demon carb to throw on it, any other little mods to make it quicker?
Old Apr 28, 2013 | 12:44 PM
greggbruce's Avatar
Re: Formula 400
oh yeah, I think the oil pan changes -- the dipstick goes on the other side....
headers SHOULD fit....
I kept my dual electric fans -- and all the computer stuff. I would think of changing to the dual fans, and a newer radiator (they are more efficient than the older ones, more fins per inch). you can hook up the fan relays to a mechaincal switch/sending unit in the block that turns them on and off when needed.
quicker? a set of 4.88 rear gears....
I'd think about a 700 or 750 carb if you're going that route, 625 seems a little small for 400 cubes....
I'd also go with a torker II intake or even a victor jr. intake (if you're doing the steeper rear end gears along with)
Old May 7, 2013 | 02:50 PM
spawnicus's Avatar
Engine: none
Re: Formula 400
which distributor did you use in the 400, the one for the 400. or the one from the 305?
Old May 7, 2013 | 03:13 PM
greggbruce's Avatar
Re: Formula 400
my car was originally a 350 formula, so I used that one because I kept all the computer stuff. You're gonna want a non computer with vacuum and mechanical advance to use with the carb setup.
about 150 or so from all the aftermarket, some less than that.
you will want the small diameter one, so it clears the firewall
Old May 7, 2013 | 03:15 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Formula 400
Make sure you find different heads for that 400. The heads on the stock 400s were terrible, which is why they made such poor horsepower in their stock form.
Old May 9, 2013 | 12:26 PM
greggbruce's Avatar
Re: Formula 400
yeah, didn't think about that.... I ran the GM aluminum heads available at the time... But now there's better available and even for less $$ --
I had the machine shop drill the steam holes in the new heads so they matched the block and head gaskets.
Linson
Oct 24, 2025 02:00 PM
FormulasOnly
Jul 23, 2018 08:47 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
okfoz
Oct 13, 2015 02:19 PM
