need some help
Old May 5, 2013 | 11:57 PM
hotrodjucky's Avatar
Car: 1988 chevy camaro z28
Engine: stock 305
Transmission: stock auto
Axle/Gears: stock
need some help
Ok need some help .ok alot of help see im use to be a ford guy but my gf that past away alittle bit ago got me in to her 1988 z28 camaro . and i loved it she wanted to take it apart and rebuild it from ground up but she was kill and now i feel i need to do it for her just cant let it sit anymore she wanted to drop a lsx 7.4 454 crate motor in it and supercharge in but dont know where to start idk what trans ill need or rear end i know she wanted a 5 or 6 speed manual in it i really want to do this but really need help
Old May 6, 2013 | 04:32 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Re: need some help
I'm sorry to hear that and we're all here to help but we need more info to work with. We arent going to tell you what to build, thats for you to decide, we are here to help with problems along the way or SPECIFIC questions that you may have. Example: We can't help you pick a transmission by you saying either a 5 or 6 speed, but if you would say something like "will my lsx 7.4 with xxx horsepower be too much for a stock LS1 T56 (6 speed) to handle? Then from expireince these guys can tell you what they have learned. Giving specific questions will get you a lot more replies on this thread than what you have now.
Welcome to TGO!
Old May 9, 2013 | 01:30 AM
Engine: stock 305
Axle/Gears: stock
Re: need some help
Ok thank im still looking around for a 6 speed but having a had time finding 1that can handel the lxs
Old May 9, 2013 | 01:41 AM
Engine: stock 305
Axle/Gears: stock
Re: need some help
Stock with a carb it has 620 hp and 200-250 foot lbs of tork thats with out the supercharger
Old May 9, 2013 | 07:21 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: need some help
Any built T56 will handle the power you need. There's also the "T56 Magnum" which is essentially a T6060 in a T56 style case. That's what I'm going with for my build.
One suggestion that I may make, is that if you're going to supercharge, an LSX454 probably isn't your best starting point. A smaller displacement motor (specifically with a shorter stroke) can be built stronger and with a more supercharger-friendly (lower compression) rotating assembly. The LSX454 is designed to be used in a naturally aspirated configuration, and is optimized for that.
Rather than choose a specific engine combo, I'd take the approach of deciding what horsepower level you want to achieve, and what other aspects are a priority (drive-ability, fuel economy, 1/4 mile times, etc), and design an engine package around that. Sticking to some of her specific desires may dictate the path you choose, but you can still do that with a combination that works.
