To swap or not to swap
Old May 8, 2013 | 05:56 PM
85SO_CALZ's Avatar
Car: 85 Iroc, 2000 SS
Engine: 350 TPI, LS1
Transmission: 700R4, 4L60E
I been debating on doing this swap for about a week, lets see what you guys think.
I have owned my 85 Iroc for about 2 years now and I was working on restoring it and planning on beefing up the 350 a little (heads, cam, ect..) but a week ago I traded a BMW I had with computer problems for a 2000 Camaro SS with 72k miles. Car looks, drives and sounds great. Its been my DD for the week I have owned it.
So my question is do I strip the SS and swap the LS1, 4L60E, gas tank rear diff. ect.. into my Iroc or hold off and keep building the 350
I have attached a picture of both cars as they sit today.
I would love your opinions, good or bad.
Thanks in advance
Attached Thumbnails To swap or not to swap-img951033.jpg   To swap or not to swap-img_20120528_163930.jpg
Old May 8, 2013 | 07:44 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Re: To swap or not to swap
What would go in the SS then? The easiest and cheapest thing to do is keep the LS1 where it is and just rebuild the 350. It'll keep the originality of the Iroc but with better performance. Also that means you'll have two cars that arent running for a while, swaps dont happen overnight.
Old May 8, 2013 | 10:48 PM
85SO_CALZ's Avatar
Thanks for the reply.
I wont have any use for the SS so ill sell or scrap the body and whatever is left over. I know swaps dont happen overnight I was going to take my time and make sure everything is done as good as possible on the Iroc. I have my Wrangler to get around till the swap is done.
Posted from Thirdgen.org App for Android
Old May 8, 2013 | 11:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Personally, I'd keep the 2000 intact and find something else for the 3rd gen. I can't see the logic of taking apart a perfectly good car and parting/scrapping it out, when you can get what you need from cars/trucks that'll never be on the road again before becoming the 3rd gen donor.
Old May 9, 2013 | 07:31 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I don't understand why you'd strip a perfectly good SS for the drivetrain. There are plenty of wrecks, or individually acquired LS parts available that will result in less net cost than sacrificing a fully functional, valuable car.
With respect as whether to modify the 85's 350 vs. an LS swap, I would want to know more about the 350 that's in it before trying to make a recommendation.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
