I am going to buy a 350, from who?
Old May 9, 2013 | 06:47 PM
backoffjack's Avatar
Car: 89 Camaro RS
Engine: 350 40 0ver
Long story short I finally determined that my 305 is not really worth fixing for the dollar so I am going to buy a 350 (will look into the 383 as well) but I don't know whom to buy it from so I am here hoping that the experts here can point me in a good direction. I talked to someone from http://www.rebuilt-auto-engines.com/ and got a $1750.00 figure on a 350 long block but I did not get into to much details other than I was looking for number at that point.
Old May 9, 2013 | 06:49 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Re: I am going to buy a 350, from who?
Look at the crate engines/long blocks that jegs and summit carry. They'll give you exactly what they say and probably a better warrenty.
Old May 9, 2013 | 07:15 PM
Car: 89 Camaro RS
Engine: 350 40 0ver
right on
Old May 9, 2013 | 08:04 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
I bought a new G.M. crate engine from jegs for 2k delivered . this is a NEW engine , ALL NEW . nothing rebuilt , good luck .
Old May 9, 2013 | 08:13 PM
Car: 89 Camaro RS
Engine: 350 40 0ver
Yeah I just got off the phone with them and the guy told me that I would also have to buy a new intake, carb and flex plate per what I have on my 305 will not work with it (that caught me off guard) so were pushing $2500 for the 290 hp engine (2000 g's 260hp)
Old May 9, 2013 | 08:24 PM
Car: 89 Camaro RS
Engine: 350 40 0ver
Is that true or is this dude on commission every other 350 I looked into was said that they interchange.
Old May 9, 2013 | 08:37 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
you don't need to change the carb and intake unless you are building something with more than 400hp, and the flexplate will swap over as long as it's an 86 and newer crank.
my suggestion: talk to local machine shops and see what they can build for you... you can get a lot more motor for a lot less money that way, and if there is a problem you can talk to the guy that put it together..
Old May 9, 2013 | 08:48 PM
Cosmik Debris's Avatar
Intake and carb should be OK, flexplate will depend on the rear main seal. Yours in a one-piece, it depends on whether the 350 is one or two.
Car: 89 Camaro RS
Engine: 350 40 0ver
I have been bouncing around on all these ideas since the day I found out that the dude I bought the car from pulled a fast one and managed to slip the fact that the 305 main bearing was spun, well the front 2 for that matter so I am skeptical on finding a used 350 but have not gave up entirely
Old May 9, 2013 | 09:20 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
You CAN swap the intake and carb over, but you wont let the engine run at full potential. They sell complete engines (from carb to oil pan) that you can buy. Obviously it will cost more but you wont need to buy any other parts, it wil come completely assembled.
Old May 10, 2013 | 06:59 PM
Car: 89 Camaro RS
Engine: 350 40 0ver
I finally found a complete 350 today for $250 so I am just going to rebuild it and look into the possibility of boring it to a 383.
Old May 10, 2013 | 08:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The stock Q-jet is a fine carb, with plenty of cfm for a 350. The intake is nothing to get excited about, but is adequate if money is tight.
Old May 10, 2013 | 10:16 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
If you are going to a 383 youll need a whole new rotating assembly and all the machine work done. So youre looking around $1500, just so you know. Theres nothing worse than starting a project you cant finish.
Old May 13, 2013 | 02:13 AM
1gary's Avatar
Actually there is one even worst than that.Buying a cheap pc of junk stroker,than cheeping out on heads so it doesn't feed the now increased cubes,and compounding it way too high SCR and a mismatched cam to the SCR.
Did I leave anything out???.
It's a common mistake I see guys making all too often leaving way too much on the table!!!.
BTW-if that is your line of thinking,save the stroker money and apply it to a matched overhead for a 355.
Old May 13, 2013 | 10:06 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
He is probably pricing you on a Vortec type eng. and the manifolds do not interchange.
Old May 23, 2013 | 02:03 AM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
carolina marine has some nice engines, they even rebuild engines, but then again so do most machine shops and engine shops, shop around your are and see what you can find
Old May 23, 2013 | 11:07 AM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
ATK
Jake_92RS
Jan 28, 2020 10:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Eric-86sc
Aug 24, 2015 09:01 PM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
theurge
Aug 21, 2015 12:46 PM
