Need help on what motor to go with
Old Jul 13, 2013 | 03:51 PM
Gregdonna's Avatar
Ok it time to pull the motor out of my 92 Z28 and i don't want to go back to the stock motor. So what should i go with i have a 350 that is 30'over that i can build or should i just go with a 383. i have been reading about guys putting a LT1 or a LS2 motor in give me the pros and cons to this.
Old Jul 13, 2013 | 07:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
350 - Pros: One of the most popular performance V8s in history. Great aftermarket support. With simple/smart factory and/or aftermarket parts choices, better than any 305 in existence.
Cons: For a relatively few more bucks, you can have a 383.
383 - Pros: As close to a bolt-in in a V8 3rd gen as a high-performance engine can be.
Cons: It's still a Gen I SBC.
LT1 - Pros: A pretty good improvement over the Gen I SBC. Sequential port fuel injection. Decent aftermarket support. The block is externally basically the same as a Gen I SBC as far as bolting it in goes, but you'll be modifying fuel and wiring systems to get it to run. Gen I/3rd gen performance exhaust works with it. 3rd gen transmissions can be made to work with it.
Cons: Limited production run. Only used in passenger cars.
LS family - The full list of cons:
- It needs adapting to fit in your chassis
- 3rd gen transmissions can be made to work, but the LS family is the better choice for several reasons, increasing the swap expense
- Fuel and wiring mods similar to LT1 in extent and expense
- Exhaust will be expensive
- Aftermarket performance upgrade choices available may make your brain spin in your skull
- You won't be able to wipe the smile off your face after you drive it the first time
Old Jul 13, 2013 | 08:53 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Need help on what motor to go with
350 is good but like stated above 383 is cheap to obtain
383 would be easy route with a miniram ,super ram or a carb
LT1 is good but I wouldn't mess with it not worth it ...but can make good power .. But it's Optispark is a huge weakness
LSx it is involved project and it adds $$$ but some things are worth the extra hassle you won't regret it
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
