i wish
Old Aug 6, 2013 | 09:17 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
i wish
someone made carb setup to tpi swap kits, i mean talk about an easy efi swap, cheap too, ohwell just a random thought i'd love tpi instead of my carb setup
Old Aug 7, 2013 | 10:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since it's easy and cheap, there's no point to it.
Old Aug 7, 2013 | 06:20 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Re: i wish
I'd take a well tuned carb over stock TPI any day.
Old Aug 7, 2013 | 08:23 PM
kmcn47's Avatar
Transmission: 5spd
Re: i wish
wanna trade then? and five7kid are you always right about everything?
Old Aug 7, 2013 | 10:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: i wish
It's called the junkyard.
Find a TPI car , remove the TPI intake , ECM and wiring parts and install them into your car.
Old Aug 7, 2013 | 10:36 PM
kmcn47's Avatar
Transmission: 5spd
Re: i wish
true thats easy enough, but i'd love brand new parts
Old Aug 7, 2013 | 10:37 PM
kmcn47's Avatar
Transmission: 5spd
Re: i wish
also have you ever been to an ohio valley junkyard? everything in it is there for a reason and none of them are camaros
Old Aug 7, 2013 | 10:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: i wish
Find a tpi intake on ebay or somewhere else that has an equally nice and new looking piece, then just purchase the standalone fuel injection system of your choosing. I use Holley myself.
Old Aug 8, 2013 | 01:20 AM
kmcn47's Avatar
Transmission: 5spd
Re: i wish
you know thats not a bad (or terribly expensive) idea http://www.ebay.com/itm/TPI-harness-fuelline-ecm-dizzy-coil-intake-runners-sensors-edelbrock-/111130843669?pt=Motors_Car_Truck_Parts_Accessories&hash=item19dfea1a15&vxp=mtr
Old Aug 8, 2013 | 02:14 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: i wish
I cant trade ya because i dont have TPI on my engine, Im a carb'd guy. One thing these guys are forgetting is a fuel pump. Along with you intake, ecm, wiring, etc. youll also need the fuel pump. Or you can go with a holley stealth ram tpi or weiand tpi which will actually be worth it.
Old Aug 8, 2013 | 12:12 PM
five7kid's Avatar
Yeah, right...
Old Aug 8, 2013 | 01:21 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Re: i wish
I'll sell you my TPI setup. It would include, fuel rails, injectors (Accel 24lbers), plenum (with a little porting), lower intake, runners, Holley AFPR, TB, MAF, all bolts, distributor cover, computer, factory prom, custom prom (to compensate for injectors/ARAP based tune). Just need wiring harness. As five7kid pointed out, easy and cheap.
Old Aug 9, 2013 | 10:05 PM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Re: i wish
Originally Posted by five7kid
Yeah, right...
Hahaha...thats funny right there.
Old Aug 10, 2013 | 02:41 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: i wish
the TPI setup isn't worth screwing around with unless you plan on doing a lot of towing.
a Megasquirt ecu and a modified LT1 intake manifold would be the cheapest way to get mpfi on your old school small block Chevy... swapping in the whole LT1 would probably be about as cheap and a lot better.. an LS swap would cost a little more and be even better..
Old Aug 10, 2013 | 02:58 AM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Re: i wish
Honestly, you'll have a larger potential power band just sticking with the carb set up
Old Aug 10, 2013 | 01:49 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: i wish
https://www.thirdgen.org/forums/elec...d-website.html
Are you banned from using the internet or receiving mail / deliveries?
Old Aug 10, 2013 | 02:12 PM
kmcn47's Avatar
Transmission: 5spd
Re: i wish
Obviously not or I wouldn't have started this thread. Not sure where your attitude is coming from.
