tired of tpi, 2 stroke plan?
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
I haven't had my car on the road for 2 years now and im tired of all the problems I saw someone with a 2 stroke v8 boat engine in there dune buggy and was wondering what tranny would you use? Im not experienced with 2 strokes but having any wisdom is great.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Car: 82 Z28
Transmission: T400
re: tired of tpi, 2 stroke plan?
You are very LIGHT on info.
Was it a 2 stroke V8 from a outboard motor ?
A outboard motor is completely different to a "boat" motor ;this is what a proper 2 stroke V8 boat engine looks like
Car: 82 Z28
Transmission: T400
Transmission: 4L80E/4L80E
If being tired of TPI issues is the problem, an LT1 or LS1 swap would seem to me to be the more sane solution.
Car: 1991 Formula Firebird WS6
Engine: 350 SB TPI
Axle/Gears: 3.23 Stockers
Re: tired of tpi, 2 stroke plan?
People DO use 2 stroke outboard powerheads as motors for dune buggies. However dune buggies use VW transmissions and they have adapter plates to nearly fit ANYTHING. Since a VW is a REAR motor car, its essentially a front wheel drive transmission flipped around backwards. And to my knowledge the never have and never will make a front wheel drive Camaro/Firebird.
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
