1988 TPI setup and ecm on 1985 block
Old Aug 24, 2013 | 03:55 PM
85Irocbuild's Avatar
Car: 1988 Gray Iroc
Hi all,
I am swapping a 1985 TPI engine into my 1988 Iroc since the original engine has developed a rod knock. I am planning on removing the TPI setup and ecm from the 1985 block and installing the 1988 TPI setup and ecm onto the 1985 engine block. Does that work? Can the 1988 TPI and ecm work with the 1985 305 engine? A friend was telling me that only the 1985 TPI ecm would work with the 1985 engine, and that the 1988 ecm wouldn't. However, I don't see why it wouldn't work. Thanks.
Old Aug 24, 2013 | 08:10 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1988 TPI setup and ecm on 1985 block
Originally Posted by 85Irocbuild
I am planning on removing the TPI setup from the 1985 block and installing the 1988 TPI setup and ecm onto the 1985 engine block.
Does that work?
The computer does not know or care what year engine it is controlling ,so long as you have the correct 305 tune in the computer
As there is no difference why would you go to the trouble of swapping the TPI intakes ?
Drop the 85 engine in and use the 88 wiring and computer
Old Aug 25, 2013 | 12:15 AM
Car: 1988 Gray Iroc
OK thank you for your response. So my final setup will be a 1985 305 engine block with a 1988 TPI setup and ecm paired with it. Sorry for my questioning, but what is the 305 tune? Thanks.
Old Aug 25, 2013 | 03:19 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Like I said why change the TPI intakes if they are already on the engines?
The F-Body 86 - 89 305 and 350 TPI engines use the same ECM (computer ) and wiring as does the Vette.
The tune on the memcal (chip ) fitted inside the ECM determines what combo it is setup for.
Even though there is no difference in the TPI intake , 305 vs 350 ; you can't use a 305 memcal ( tune ) to run a 350 or vise versa .
Old Aug 25, 2013 | 07:35 AM
Car: 1988 Gray Iroc
Ok so I am good then. As for why I am changing the TPi intakes, when I remove the 1985 305 engine, I will be removing the heads on it and installing new ones. The 1988 TPI plenum and runners are in better shape than the 1985 plenum and runners. Since the 1985 TPI plenum and runners will already be off anyway, I will just replace it with the 1988 TPI setup. Thanks for all your help.
Old Aug 25, 2013 | 07:38 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The 1988 TPI plenum and runners are in better shape than the 1985 plenum and runners. I will just replace it with the 1988 TPI setup. .
But as they are the same item you should stop calling them a "85" and a "88" ; only causes confusion
All you are doing is replacing one early TPI intake with another one in better condition
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
