Building a vortec headed 350 need help on rocker arms
Old Sep 24, 2013 | 06:21 PM
mike22115's Avatar
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
I'm building a 350 with vortec heads, I want to know what are the best rocker arms to use with vortecs, I've been told scorpions work good because they have the narrow body to clear stock valve covers. Also ill need guide plates, are they specific for vortec heads or will any sbc ones work?
Old Sep 24, 2013 | 08:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Building a vortec headed 350 need help on rocker arms
If you use guide plates, any normal style rocker will work. Without guide plates you will need self-aligning rockers.
Old Sep 24, 2013 | 08:11 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Just make sure you don't use guide plates and self-aligning rockers. That caused me a bunch of valve geometry issues.
Old Sep 24, 2013 | 10:16 PM
mike22115's Avatar
I just want to make sure what ever I get will clear stock valve covers and I heard only the narrow body will clear...correct me if I'm wrong
Old Sep 24, 2013 | 10:45 PM
RyanJB's Avatar
I wouldn't risk it, those covers aren't the tallest things out there.
Old Sep 25, 2013 | 07:21 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Height is not the issue
A narrow rocker is required to clear the 4 pedestals that the cover mounting bolts go through to the head .
Old Sep 25, 2013 | 08:47 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Yep, the narrow body SA scorpion rockers fit just fine under the stock covers. Im running them.
Old Sep 25, 2013 | 08:53 AM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
http://www.summitracing.com/parts/sum-g3314
These are the covers I have and I had to remove a little metal from them to clear my Scorpions. It was easy though.
Old Sep 27, 2013 | 06:45 AM
1gary's Avatar
Are you going to increase the rocker ratio or using a cam bigger than 500 lift?.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
