hey im building a 1991 camaro that i swaped the tpi powered 305 out and i currently have a 1963 283 out of chevy 2 in it im using the 305 heads bcuz the 283 heads doesnt have the right holes for the mounting brackets that hold all my accessories like the alternator and such...and of course im going old school with a carb and a Hei distributor and with that comes my problem.i need 2 make a custom mounting bracket for the throttle cable any suggestion on how 2 do that would nice plz
Jim85IROC
close
Sorry to hear about the downgrade. With respect to your throttle bracket, I would recommend that you just get a new throttle cable that's designed to work with a carb, and buy an appropriate bracket. There are plenty of throttle cable brackets available for GM applications for every popular carb style.
Why the **** would you swap out a Tuned Port 305 for a carbed 283 from 1963?! That thing probably puts out 140 net HP, if that.
Quote:
NostalgiaOriginally Posted by _Nick_
Why the **** would you swap out a Tuned Port 305 for a carbed 283 from 1963?! Member
Sonic check the bores on that 283 take em to 4.00"'and you'll have a 302" !
Jim85IROC
close
Quote:
Sure. Just add some 5" bias ply tires for full effect.Originally Posted by vetteoz
Nostalgia sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,454 Times in 1,874 Posts
Quote:
Nostalgia
As TERRIBLE as a 305 TPI usually is, I guess sometimes we gotta step back in time (at least, those of us who weren't there at the time, would have to take the step back), and remember that our grandpas had it EVEN WORSE. Nostalgia
Common-sensical thing to do (besides INCREASING your cubes, instead of DECREASING) would be to simply get a stock bracket off of a carbed car with a 700; about anything 83-87 should do the trick. Car, truck, Caprice, Camaro, makes no difference. Quick trip to yer local buzzard nest, it'll all be cured.
five7kid
close
Get the throttle cable while you're at it.
