Throttle linkage & Cable brackets help. Please
Old Oct 30, 2013 | 09:05 PM
84firebird1996's Avatar
Car: 1991 Trans Am GTA
Engine: LT-1
Im in need of the brackets that bolt to intake manifold to hold the TV Cable and Throttle Cable in place. My question is can i use any brackets off of any year vehicle? I have a 91 trans am with a carbed 355.
Also i bought my holley 750 with a Ford kickdown setup. What do i need to buy to run my gm throttle cable and 700-r4 tv cable?
Thanks in advance
Old Oct 30, 2013 | 11:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Throttle linkage & Cable brackets help. Please
https://www.thirdgen.org/forums/post...026-post7.html
The TV corrector bracket for the carb linkage
http://www.summitracing.com/int/sear...ctor%20bracket
What are you doing about the convertor lockup ?
Old Oct 30, 2013 | 11:29 PM
Engine: LT-1
Thanks and what about it? i have a 3200 stall 10"
Old Oct 30, 2013 | 11:31 PM
Engine: LT-1
and do i need to replace my throttle cable? I have the throttle cable for a LT-1 which has the little rod at the end of the cable that slips onto the throttle body on the lt1.
Old Oct 31, 2013 | 06:35 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Need a cable from a 3rd Gen carb car or early TPI that fits on a ball stud like a carb uses
Old Oct 31, 2013 | 06:51 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
MY 86 LG4 throttle linkage is not a ball stud style linkage. The carb uses a stud with a retaining clip to keep the linkage from sliding off. The TPI throttle cables tend to bind because of their length so most people swap them out for a throttle cable from an LG4 car.
LT1Formula
20
Nov 14, 2015 12:02 AM
Genopsyde
Nov 11, 2015 10:46 PM
hydrolic144
Oct 4, 2015 08:23 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
