engine not firing
Old Oct 31, 2013 | 09:21 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Engine: 350 TPI STOCK
engine not firing
Need some help!!!
I just replaced a 305 with a 350 on my 90 iroc. As you know, I kept the TPI system but got new heads (stock for 350) and roller rocker arms. The knock sensor is new for 350 and rebuilt yellow fuel inj for 350. The engine turns but won't fire. Fuel pressure is good, fuel inj cables are ok (I used a noid light), also got a spark (yellow) when testing spark plug cables. The distrubutor is new, coils is new. Distributor is pointing #1 on TDC. Valves adjusted properly, I think. After crancking for a while and no internal combustion I check the plugs and noticed a strong fuel odor. Does not make sense since I see spar in cables. Help please!!!!
Old Oct 31, 2013 | 11:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: engine not firing
https://www.thirdgen.org/forums/tech...formation.html
Originally Posted by wruiz
fuel inj cables are ok (I used a noid light), also got a spark (yellow) when testing spark plug cables.I check the plugs and noticed a strong fuel odor.
Does the engine sound like there is any spark ; a kick , burp , f*rt , any noise at all ?
If the injectors are firing as you say and the plugs are wet then you don't have spark , or enough of it.
Seeing a spark outside the engine does not mean it is strong enough to fire the mixture when inside the cylinder.
Do the basic spark tests
http://easyautodiagnostics.com/gm_ic...n_module_1.php
to confirm your electrics are as good as you think
Old Nov 9, 2013 | 07:23 AM
Sam L.'s Avatar
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
it may be a computer program but as vetteoz said make sure all electronics are as good as you say. good luck
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 9, 2015 05:27 PM
