Fuel pressure regulator need help guys!
Old Nov 14, 2013 | 10:44 PM
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
I am ready to plumb in my regulator and I am not for sure on what one I need I have the stock in tank pump from the 3.1 I am going to be running a 750 holly dp. how mutch do i need to regulate it down. Also is there better lines out there I can run instead of the stock ones they got on the car I am going to move the fuel filter closer to the carb and put a nice inline one. any is appreciated!
Old Nov 15, 2013 | 05:06 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: Fuel pressure regulator need help guys!
I put a return or bypass style regulator on my truck with the stock in-tank pump, This reduces pump back pressure. I've got my Demon carb running at 6 lbs. just to assure it doesn't blow the needles off the seat since 7 lbs. is max, I also had issues with ethanol drying out fuel lines and making them hard and crack...... I went to Summit and got braided line and fittings couple years ago and their still soft and pliable......
Old Nov 15, 2013 | 06:28 AM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
thanks man thats exactly what i needed
Old Nov 16, 2013 | 08:47 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
I have a areomotive I think its spelled holds pressure great its alittle pricey but well worth it
Posted from Thirdgen.org App for Android
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
