Will my TPI setup fit on an older 350 block?
Old Dec 10, 2013 | 03:53 PM
MattGibson1's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.0
Axle/Gears: stock
Hey guys, I have a '89 Iroc with the 305 tpi. I was wondering if my tpi intake would fit on an older 350sbc. I can get a pretty good deal. And since I have centerbolt heads could I just put them on the 350 and run higher compression?
Old Dec 10, 2013 | 05:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The block doesn't really care.
You can run your 305 heads on a 350 block. If your 350 has dished pistons, it's a good way to bring the compression back up. If the 350 has flat tops with valve reliefs, you need to watch your CR - might be too high.
Old Dec 10, 2013 | 08:09 PM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
Re: Will my TPI setup fit on an older 350 block?
the only problem that you will have is the angle of the manifold to head bolts, you may have to "egg" out the bolt holes in the manifold. On my LT1 /TPI, I had to move some of the bolts. Nota big deal.
Old Dec 10, 2013 | 09:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Just like on the aftermarket intakes that fit both style heads
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Sanjay
Aug 12, 2015 03:41 PM
BBSDesigns
Aug 11, 2015 07:39 PM
squiggy2
Aug 9, 2015 09:30 PM
