305 tbi parts swapped onto a carbed 350..?
Old Dec 13, 2013 | 07:25 PM
Elvis'92Bird's Avatar
I'm currently running a 305 tbi in my 1992 Firebird. I bought a carbed 350 with a mild cam, slightly lopey, unsure on the cam size. My question is, could I use the tbi intake, throttle body and distributor to convert it to 350 tbi using the 305s parts? Will a cam throw the computer off, is a tune recommended or neccesary? Thanks.
Any other tips would be greatly appreciated, actively looking up info, just looking for extra input.
Old Dec 13, 2013 | 11:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 305 tbi parts swapped onto a carbed 350..?
Originally Posted by Elvis'92Bird
Icould I use the tbi intake, throttle body and distributor to convert it to 350 tbi using the 305s parts?
Whether it will run on a stock 350TBI tune depends on the cam specs
https://www.thirdgen.org/forums/tbi/...-350-swap.html
Old Dec 14, 2013 | 06:15 AM
Just replacing a 305 with a 350, the tune needs to be different.
If the cam is even "slightly lopey", the tune will be REALLY REALLY off.
Best plan might be to put a KNOWN more appropriate cam in it instead of guessing around what might be an unsolvable problem, and get the chip, knock sensor, ESC module, and injectors, off of a 350 at the junkyard.
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
MENINBLK
Aug 5, 2015 11:58 PM
