5.7 accessory brackets question
Old Dec 22, 2013 | 03:11 AM
RaceFace's Avatar
Car: 1987 F-bird
Engine: 350 Vortec
Transmission: Manual
Hi, guys!
I've got my engine from the truck, so i already ordered new flywheel, heads, cam, clutch etc... Now i discovered that truck brackets won't fit my car.
So, i'm trying to clarify whether V6 4.3 accessory brackets will allow to close hood on Firebird with '93 5.7 installed. I know, 4.3 brackets will bolt right in V8, but there's nothing told about alternator and AC clearance to hood.
And if somebody has gone through brackets swap to March or similar ones, please, show me exact type of needed (alt on driver's side, AC on passenger), there's a mess in my head now after reading lots of info.
Thanks in advance!
Old Dec 22, 2013 | 08:01 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: 5.7 accessory brackets question
I tried this with brackets a serp belt set up from a 94 4.3, no they will not work, they stick up a good few inches above the fender line, not a chance of closing the hood. You have to get the brackets for our cars, they have the A/C and alternators positioned low enough to close the hood, others have them sitting up too high.
Old Dec 27, 2013 | 05:48 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
I had truck accessories in my 85. Fit just fine even with the stock hood. They were off of a 1993 4.3 c1500.
Genopsyde
Nov 11, 2015 10:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
