bbc/carbed sbc in a thirdgen?
Old Dec 22, 2013 | 11:53 PM
MattGibson1's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.0
Axle/Gears: stock
Sorry to bring this up again but I need a lot of info or personal advice. My iroc has a 5.0tpi and it's on its last leg. I've always hated this motor and I'm sad to see it go, but I'm glad to watch it leave. I'm definitely looking for some different setups. But not sure what I should do. At first I was thinking about buying a vortech 350 from a suburban or something because a friend of mine got one super cheap and with less than 1,000 invested made a pretty good little street runner. But what about a bbc? I've seen people say it's just as easy as swapping a regular sbc and some that say it's like pulling teeth. My budget is around 1200 not counting the stuff I could sell off of the motor now. Anyone have any suggestions or good links? Any help would be great appreciated.
Old Dec 23, 2013 | 11:04 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: bbc/carbed sbc in a thirdgen?
I don't think a reliable BBC swap could be done for $1200. A good small block swap costs nearly that.
Old Dec 23, 2013 | 12:45 PM
And that's AFTER you already have the "good small block".
And THEN, figure on another $2000 - 2500 in exhaust, drive train, transmission, and suspension upgrades, BARE MINIMUM.
A big block will run up more cost than that, if for no other reason, it will tear stuff up even faster.
If all you've got is $1200, I'd advise that you keep your money in your pocket, and save up until you have about 3 times that much. Then you MIGHT be ready to talk about a big block swap, assuming you can get the big block itself FOR FREE.
Old Dec 24, 2013 | 09:33 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I agree
Old Dec 25, 2013 | 07:01 AM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
IMHO, I would buy a L05(88-95 truck) 350 shortblock, freshen it up and just swap your stuff onto that. You can pick one of them up for a few 100.00 bucks, 4-500 to freshen it up, then a few 100.00 for misc stuff. That should keep you with in your budget, give you a little power boost and not hack the car up.
Old Dec 28, 2013 | 12:51 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Originally Posted by 572_Rat
I agree
Agreed. But if you still dont get it, look at it this way, even if Santa dropped-off a 572"Deluxe" Crate motor by accident, or on purpose, you still have to exhaust it, fuel it, cool it, and then what, hope everything else behind it survives? Cant do all of that under your budget.
Old Dec 28, 2013 | 02:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Well, in reality, you could install a basic junkyard BBC under the hood with nothing more than some aftermarket headers so solve the exhaust issue but performance wise, it would be less than a mild SBC. Considering the required headers alone are around $700, that doesn't leave much in a budget for anything else.
For a proper complete BBC swap, you need a budget closer to $5000 or more to get everything done that should be required for the swap to be done properly.
Terrell351
Jun 13, 2021 01:13 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
sreZ28
Aug 14, 2015 07:48 PM
BBSDesigns
Aug 11, 2015 07:39 PM
