new third gen engine install
Old Dec 29, 2013 | 06:18 PM
junk yard dog's Avatar
Car: 91 z-28
Engine: 350 camel hump heads 480 lift cam
Transmission: 700 r 4
Hey everyone, I bought a 88 z-28 it had a 305 in it but was mostly torn down. I finished tearing out the 305 and assembled a 350 with the tpi on it. I got it all put In And got everything hooked up I think, since I didn't do the whole tear down I did my best to hook up everything. So it has a five speed by the way. So I am missing something because it won't crank and I don't hear the fuel pump but I do have headlights and a cooling fan that must be wired directly to a ignition hot wire cause it works. But that is all got I know it could probably be a bunch of things but is there something that screems out hey you forgot to hook me up like a sensor or power wire to the ecu or something? I do have power to the starter.
Old Dec 29, 2013 | 07:07 PM
Chad85T/A's Avatar
Car: 85 T/A
Re: new third gen engine install
I believe I would start by testing the FP hot wire. You can locate it between the back seats where it goes through the body to the tank. I would also check the ign wire to the starter solenoid.
Old Dec 30, 2013 | 06:38 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Did you play with the clutch petal while tearing this down, if so check under the dash to make sure the switch was not put out of place. I just did that, mine would not crank and that was the reason
Old Dec 31, 2013 | 02:05 AM
87irocZ28Crush's Avatar
Car: 1987 Iroc Z28
Make sure you have all the grounds on the back of the block. I know there are 2 might be 3 that get bolted to the back of the block.
Old Dec 31, 2013 | 02:25 PM
vt89rs's Avatar
Car: 89 Camaro RS, 79 Camaro z28
Engine: 385 stroker
Axle/Gears: 3.23 posi borg warner
just what the last guy said, check the grounds that go to the back of the block/heads at the fire wall. I had the same problem and it was just one little ground wire and it drove me nuts!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
