Overall Best bang for your $$$$$
Old Feb 6, 2014 | 05:29 PM
thomas707's Avatar
Car: 1989 RS Camaro
Transmission: TH700R
Axle/Gears: No posi YET!
Finally over shortage on cash and problem after problem the 89' is finally in the shop. So after talking with the mechanic I decided to replace the engine with a new remans 305. I was quoted at 3,200 after parts and labor (block was 1800) this is at 97$ an hour. I decided why not 350, was my original Idea so I'm looking into these. I read a lot but I just cant understand the numbers and outputs these spec mean if that makes any sense.
Thanks,
Thomas
1st
http://high-performance-engines.com/...duct_Code=VC01
2nd
http://high-performance-engines.com/...duct_Code=HP31
3rd
http://high-performance-engines.com/...duct_Code=HP29
Old Feb 6, 2014 | 06:23 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Overall Best bang for your $$$$$
Just a couple of things I noticed....
You would need a balancer yours won't work (wrong timing mark)
The picture shows Vortec heads on that motor (takes a different manifold)
67cc heads won't produce 9.6 compression
#3 is the only one that works for your car. (one piece RMS)
Has a weak cam
Old Feb 6, 2014 | 06:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I wouldn't trust a photo on a website. The description doesn't mention Vortec heads, and the application says "TBI" and "1987-1995 Trucks" - pre-Vortec.
Old Feb 6, 2014 | 06:32 PM
Dyno Don's Avatar
And they don't have 67cc heads
Old Feb 6, 2014 | 07:30 PM
thomas707's Avatar
Car: 1989 RS Camaro
And by weak do you mean not aggressive or just a poorly made product.
Old Feb 6, 2014 | 07:31 PM
thomas707's Avatar
Car: 1989 RS Camaro
And the tbi truck motor wouldn't b plug and play.
Old Feb 6, 2014 | 08:08 PM
Dyno Don's Avatar
Just smaller than a TPI cam. (and they're mild)
My comments were made to help you investigate a little more.
Old Feb 7, 2014 | 06:52 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Just another FYI if you plan to swap to a 350. You will need injectors with more flow capability for the 350 and I would also recommend getting a new Mem Chip for the ECM as well.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Ghettobird52
Apr 21, 2020 08:44 PM
mustangman65_79
Apr 14, 2017 05:37 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Mr. Chevy
Sep 11, 2015 06:06 PM
