Solid motor mount problem
Old Feb 12, 2014 | 04:12 PM
Hirevsjoe's Avatar
Car: 86 Z28
Engine: 383 sbc
Transmission: th350
Axle/Gears: 4.56
Hey guys, maybe someone can help me out here. I ordered solid motor mounts for the 86 I'm putting together for my son. Ordered both block and frame mounts from Jegs. However when I swing the engine and trans in for mockup, they are no where near close. I measure 16 1/2 from center to center on frame hole, but 17 1/4 from center to center on the block side. Has anyone else ran into this problem, is there something I'm missing. I called Jegs and they never heard of this. I have a parts car and tried to mounting them in that car to see if I had a problem with the K member. The same problem with that car. If anyone can help I would be very grateful.
Old Feb 13, 2014 | 07:16 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Re: Solid motor mount problem
About 10 years ago I ordered Moroso solid motor mounts and frame mounts for a V6 to V8 swap. Things lined up nicely but there are two frame mount locations on the K-member. One is for the V6 and the other is for the V8. You have to make sure you mount the frame mounts in the right location.
The Moroso's part numbers are 62510 (motor) and 62610 (frame).
Also make sure you got shipped the right parts. I have had the wrong part, not the one I ordered, shipped to me once. Mistakes happen.
Old Feb 13, 2014 | 09:04 AM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
I had the same ones that bestracing is talking about. I ordered them for my '85 T/A when I was swapping in a 350, and reused them on my '91 RS. Great mounts, just don't torque them down all the way until you have the engine and trans in.
Old Feb 13, 2014 | 03:04 PM
Hirevsjoe's Avatar
Car: 86 Z28
Engine: 383 sbc
Transmission: th350
Axle/Gears: 4.56
Thanks guys. The mounts are in the correct location. After looking further into the part numbers of the mounts we have,I now see that they sent my son the Jegs version of the Moroso mounts. I thought we were getting the Moroso mount part # you have listed above. I talked to Moroso this morning and they say that the frame pads look the same, but one side should be taller then the other. The ones I have here from Jegs are the same height. Have you guys seen them this way. Just would like to be sure before i go and order another set of mounts and they are the same I have.
Old Feb 13, 2014 | 06:29 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
My Moroso mounts came labeled driver side and passenger side, even so they were a PITA to get in the car
Old Feb 13, 2014 | 07:21 PM
Hirevsjoe's Avatar
Car: 86 Z28
Engine: 383 sbc
Transmission: th350
Axle/Gears: 4.56
572 Rat, did you buy the 62510 and 62610? Thanks for the help guys.
Old Feb 14, 2014 | 09:24 PM
Hirevsjoe's Avatar
Car: 86 Z28
Engine: 383 sbc
Transmission: th350
Axle/Gears: 4.56
So I talked to Moroso today and they gave me the measurements for the mounts and the are different left and right. The mounts that Jegs sold me are either packaged wrong or plain just don't work. Correct Moroso mounts are on their way. Hopefully we'll be back on track the beginning of the week.
Old Feb 15, 2014 | 05:02 AM
572_Rat's Avatar
Yes, those are the same mounts
Old Feb 17, 2014 | 09:49 PM
Jwech's Avatar
Car: 88 Camaro
Engine: SBC 350
Transmission: Turbo 350
Axle/Gears: 4.11 9 Bolt
Had same problem just bought the Jegs motor mounts, tried to install them and they didn't fit.. Problem is with the pad to frame mount. Pad on drivers side should be shorter than passenger side. Confirmed this cause I was lucky enough to buy the Moroso ones locally.
The driver and passenger frame pads are different in height. The mount to block are the same.
Old Feb 18, 2014 | 10:38 PM
Hirevsjoe's Avatar
Car: 86 Z28
Engine: 383 sbc
Transmission: th350
Axle/Gears: 4.56
Well finally got it all worked out. Ended up picking up Moroso block mounts locally and using the Moroso lower mounts I got from Jegs. The Jegs lower mounts that they sold me will not work, they are the same mount left & right. Thanks again for all the help.
Old Apr 13, 2014 | 03:25 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Hate to bump this but I just tried to install my jegs motor mounts and ran into the same problem.
Just ordered the moroso mounts and sent jegs an email to get 82-92 camaro/firebird removed from the compatibility list since they clearly don't fit anyones car.
So just to cliffnote.
Jegs motor mounts don't fit
Buy moroso mounts
Try not to be angry
Old Apr 14, 2014 | 07:16 AM
bestracing's Avatar
Engine: Broke - 350
Bumped for a good reason since you verified others results but not good for the fact that you had to deal with the frustration of it all.
jhawkeye
May 25, 2022 06:33 PM
Wesly_66
Aug 26, 2015 09:55 PM
Street Lethal
Aug 13, 2015 08:28 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
