305 to 350
Old Mar 5, 2014 | 10:30 PM
kenjames23's Avatar
Car: 1982 Z28
Engine: 350 880 block
305 to 350
Okay i have a 305 i am pulling this weekend and i am going to replace it with a '96-'99 light truck 350 casting number 10243880 GM 5.7LG. SGI.It has heads casting number 14102193.I have 2 sets of heads 3973487 and 14014416.what ideals do you guys have for this 350 build just want to pick your brains and then decide what i am going to build.Thanks for any replies and answers.
Old Mar 6, 2014 | 11:17 PM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
Re: 305 to 350
96 to 99 is a vortec motor, or are you working on a vortec truck. if you are you may want to go over to GM Truck Central .com those guys are up on the Vortec stuff
Old Mar 11, 2014 | 04:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you sure about the source of the engine? While that block casting was used in '96-'99 Vortec engines, it wasn't used exclusively for those engines. It was also used in '95 LO5 TBI engines, crate replacement engines, crate performance engines, etc.
The heads are LO5 TBI heads - aka, "swirlports". While not necessarily horrible, they aren't considered the best for a "performance" build.
So, that begs the question - What are your plans for the engine and car? The 3 sets of heads you mention are from 3 different eras. The 487s are 75cc chambers - they were decent back in 1971, but not a very good choice (don't have hardened seats, would require domed pistons for decent compression ratio). The 416s are 58cc chambers used on 305s - okay, but the intake valves are small, and compression will be too high on a 350 unless you have dished pistons. The 487s and 416s have the '86-earlier intake mount bolt pattern, while the 193s have the center two bolts on each side at 72 degrees (instead of 90 degrees like the rest) - this would affect your intake choice.
So before you can pick our brain, we need to pick yours to know more about your plans. Let's start with what you will be doing with the car, and what induction (carb, TBI, TPI, etc.) you plan on running.
Old Mar 11, 2014 | 11:09 PM
kenjames23's Avatar
Car: 1982 Z28
Re: 305 to 350
just building a every driver not racing did all that in the 80's but i do want something strong for my 1982 z28 camaro
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
