Change 350 carbed to TPI??
Car: 92 RS Camaro T-Top
Engine: 305 V8
Transmission: 5 speed manual
Axle/Gears: stock
So i just bought a carbed 350 out of an 88 chevy suv for 500 to replace the 305 TBI in my 92 camaro. Its been re-built about 10,000 miles ago. I would like to get a decent amount of HP out of it, so i will be doing a re-build... Again... I would like to Change it to a 350-383 TPI. Does anyone know what might be entailed in the swap?? I already have all the 3.5" exhaust ready and the Headers. Any advice??
Transmission: 4L80E/4L80E
If they are the stock '88 350 TBI heads, they gotta go.
Engine: 305 V8
Axle/Gears: stock
Re: Change 350 carbed to TPI??
I believe he said that they are aftermarket aluminum heads. I'll have to look again.
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Plan on a new wire harness for all the new injectors, A new TPI in tank Fuel pump, computer chip upgrade that's just a few things that will be required. Many surprises to come! Have fun and GOOD LUCK!
im having an issue kinda like this. I have a 86 iroc with the 305 tpi but my Pa is letting me have a 350 carb outta one of his chevys and im wondering what it would take to keep it fuel injected tpi? or will I have to find a way to make the carb work???
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You will need a 350 tune ( prom ) in your existing ECM , 350 injectors and a 350 TPI knock sensor
Only consideration is what cam is in the new 350 ; not all are compatible with computers
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
