305 tpi to 350 swap issues?
Old May 2, 2014 | 08:11 AM
Budget88street's Avatar
Hey guys, here's some back ground on the car first off. I bought an 88 305 tpi camaro z28 with a fiberglass front clip, fenders and hood for 1500. Sounds to good to be true? Well it was the engine had a minor miss. Went through a basic tune up. Cleaned up the miss and the engine developed a real bad knock. I was able to buy a junkyard 350 tbi out of a old silverado for 150$. Swapped my tpi, installed the engine. Here's my issue engine runs great but I can't seem to get the transmission to engage. I can select gears but nothing grabs? Any ideas guys? Tranny is a 700r4
Old May 2, 2014 | 02:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Did the transmission work before you pulled the 305?
Are you sure the torque converter is properly engaged with the transmission front pump?
Old May 2, 2014 | 10:12 PM
Re: 305 tpi to 350 swap issues?
I finally figured it out, had a torque converter issue
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
