91 camaro z28 starting problems!
Old May 21, 2014 | 07:02 PM
skinnyboy21's Avatar
i have a 91 camaro z28 with a 305 bored .30 over. After getting the car to operating temperature it wont start. If i let it set their and cool down it will start right back up about 20 mins later without spray starting fluid in it. I figured it may have been the fuel pump getting weak so i changed it, then i changed everything in the distributor as far as the button and cap, changed wires and plugs, and its still doing it. When it wont start i throw my fuel pressure gauges on and its normal, and i check the spark and its good. I was thinking maybe the security but all i have to do is spray starting fluid in it and it will fire right up. Any suggestions or anything would be great! Thanks
Old May 21, 2014 | 08:55 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Re: 91 camaro z28 starting problems!
Sound similar to what I was JUST going through. I see you did install a new cap and rotor, did you replace the ICM? I did and problem solved. I also read here the fuel injectors if old as well as the coolant temp sensor can be the issue too. Hope this helps!
Old May 21, 2014 | 09:04 PM
Nah buddy i sure didnt replace the ICM. And yea after getting use to this site i seen some people talking about injectors could be the issue. And i didnt think about the coolant temp sensor that didnt cross my mind forgot about that. But thanks man ill try that and see what it does. Appreciate it!!!!!
Old May 21, 2014 | 09:21 PM
Engine: 5.7
Axle/Gears: Stock
DARN. I know the fustration but stick with it, you will get it fixed. I love this website, so many cool folks helping out. Let us know how it works out for you and best of luck!
Old May 22, 2014 | 04:40 AM
JunJun's Avatar
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
I doubt the IAC valve too...
Old May 24, 2014 | 05:23 PM
Engine: 5.7
Axle/Gears: Stock
Let us know how things turn out! all the best.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Aug 8, 2015 12:07 PM
