Few questions about swapping an engine from an 1988 camaro
Old May 26, 2014 | 08:46 PM
1984tecate's Avatar
Car: 1988 GTA Trans AM
Engine: LB9 5.0 305
Axle/Gears: 3.45
I have a 1988 camaro that has a 2.8 v6. I want to swap out the engine to something a little bit better. i want to put a 305 from a 86 trans am in the car i found a few engines for pretty cheap. I was wondering what i have to change on the car to put that engine in. Do you i have to get a different transmission? also would there be anything special i have to buy or look out for? - thanks
Old May 26, 2014 | 09:00 PM
steveo_'s Avatar
Re: Few questions about swapping an engine from an 1988 camaro
it's a bit of a project, but actually not that bad.
the rear gear ratio will be a bit high, but it'll work
yes you should swap the transmission too
your front end ends up sagging a bit too; v8s got heavier front springs, but it's not a big deal
just keep in mind the little things; rad hoses, fuel lines, ground points, TONS of stuff is different.
a wrecked donor car is best so it doesnt nickel-and-dime you to death
Old May 26, 2014 | 09:04 PM
1984tecate's Avatar
Engine: LB9 5.0 305
Axle/Gears: 3.45
Will a 305 bolt up to the v6 transmission? or will i have to get a new trans?
Old May 27, 2014 | 04:15 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Obviously didn't look at the top of this page
All your questions answered
V6 to V8 Swap - READ BEFORE POSTING NEW!
https://www.thirdgen.org/forums/engi...swap-read.html
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
reiderz iroc
Aug 13, 2015 04:57 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
