Vortec 350
Old May 28, 2014 | 01:03 PM
deity4uu's Avatar
Vortec 350
Need a little help. I am going to swap the 305 TPI in my 1991 z28 convertible for a 350. Scoggins Dickens is selling a new vortec 350 for $2,109.00 (shipping included) with a TPI base intake for another $348.00. TRi-Star engines is selling a re-manufactured OEM 350 for $2,250.00 (this included shipping and core charge). What engine do you guys recommend? I will not be racing the car but do want a little get up and go.
Old May 28, 2014 | 01:17 PM
jokerZ71's Avatar
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
Re: Vortec 350
The new Vortec fron SDPC.Why buy a reman when you can get brand new for less.The new motor should also come w/ a 100,000mile/5 yr warranty,IIRC. Is the TriStar an L31/Vortec,or,just a reman 350?
Old May 28, 2014 | 01:27 PM
deity4uu's Avatar
Re: Vortec 350
Because the vortec 350 is not a factory replacement to my 305, Scoggins is only offering a 1 year/12k miles warranty. Tri-Star's engine is a remanufactured TPI 350. Will a vortec, being that is a truck-based engine, have good performance compared to a car-based 350? Also, other than the TPI base plate, a 350 prom, knock sensor and larger injectors, will the vortec engine work in my car?
Old May 28, 2014 | 02:01 PM
jokerZ71's Avatar
Engine: 5.7 Vortec
Axle/Gears: 3:42
Re: Vortec 350
Yes the Vortec will work.I'm not real familiar with the TPI 350 & it's rating,but,a stock L31/Vortec will easily make 300 HP with 750 cfm of fuel/air & headers.Tuning will be necessary as will configuring an EGR,if you have to comply with emissions.
Old May 28, 2014 | 02:12 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Vortec 350
You can also buy them from jegs
http://www.jegs.com/i/Chevrolet+Perf...30283/10002/-1
Old Jun 6, 2014 | 11:50 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
Re: Vortec 350
I have one from summit, no good from the get go. did not break in correctly, about 30,000 miles now, needs a rebuild, uses oil like a sonofabitch. but runs o.k.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Stryker412
Sep 7, 2015 09:11 AM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
