305tbi Engine Swap HELP
Old Jul 23, 2014 | 06:14 PM
atlboy4321's Avatar
Car: 1992 RS Camaro
Engine: 5.0 H/O
Transmission: 700r
Axle/Gears: 3.43
Hey everybody I plan on swapping my 305tbi out my 92 rs camaro.
Im looking to get atleast 300+ Hp. What is the best and easiest route to go?
What engine can produce that hp? Will swapping to a 350tbi/355?tbi/383tbi be the easiest or will going carb be the easiest?
If you done a 305tbi swap for a bigger engine please give me some suggestions. Thanks in advance!
Old Jul 23, 2014 | 07:24 PM
fiveoformula's Avatar
Car: 1988 Formula Firebird
Engine: 5.3 LM4
Transmission: 4L65E
Axle/Gears: 3.42 True-Trac
Re: 305tbi Engine Swap HELP
Depends on what you consider easy really.
Some people really like fuel injection, since they can tune while driving with a computer.
Some swear by carbs.
keeping it TBI the way it is will be easier in the sense that you don't have to worry about swapping anything.
Changing to carb would be easy in the sense that getting the tune initially dialed in will be simple as turning screws.
Getting both tuned to run well is somewhat difficult. It takes work and tons of research.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
armybyrd
Aug 10, 2015 09:23 PM
