305 HO to 350 vortec
Old Aug 3, 2014 | 09:11 PM
dodgeitclevelan's Avatar
Car: 1985 iroc z
Engine: 305 HO
Transmission: t-5 5Speed
Axle/Gears: 3.73 rear diff
I just bought a 85' iroc z with a 305 HO with a t5 manual tranny. I just blew both head gaskets (the belt on the water pump was loose). So I figured this would be an excuse to dump a 350 in. I have been doing my research for about a week now and I just want to make sure I have everything right. I was going to get a 350 vortec from a tahoe or something like that from a junkyard. I will put the engine on the engine stand and replace all the gaskets. Get an aftermarket intake to fit my carb on it. I will also get a new set of headers. Then everything else will bolt right up. Is this a good plan? I plan on building a 496 stroker to put in it but I want to still drive it because I want my baby back for the weekends lol. Thank you guys for all your help.
Old Aug 4, 2014 | 07:48 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 305 HO to 350 vortec
you should have no real problems.and good choice on your car.
Old Aug 4, 2014 | 07:50 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Great plan but you do know it will shred that T5 right.. If its not a built one to handle that extra power. Theres a reason they didnt put it behind the 350s from the factory.
Old Aug 4, 2014 | 10:44 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Sounds like you are planning the same as I. I have a L98 out of an IROC with vortec heads 2-3 weeks from being rebuilt. Bought some custom dyno don headers, had the qjet rebuilt with the 350 in mind, and yes I plan to keep the T5 until it breaks. Why throw away or practically give away for $300 a perfectly good tranny when I could just have some fun and break it the old fashioned way?
Actually, you'd be suprised how many people actually have had success with their T5's and Vortecs. It can be done. And the Chance to upgrade to a T56 will always be there
Good luck!
Old Aug 5, 2014 | 07:26 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Yes there is a reason they did not but it has nothing to do with the power of a 350. I wish that damn myth would just go away. It had more to do with having to redo emission testing which is crazy expensive and was not worth it in GMs book.
GM put a t5 behind the 92 5L TPI making more power than the 5.7 in 86 with only a 20 ftlb of tq difference.
A T5 in good shape can live a long life behind a L31 if you don't drive like an **** all day and miss third.
Old Aug 5, 2014 | 02:57 PM
Car: 1985 iroc z
Engine: 305 HO
Thanks for the reply guys and after I do the swap I plan on putting a t56 tranny any way I will probably be 6 months from now tho if I does break I can always my 02' Firebird any ways lol
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
Dwayne614
Sep 28, 2015 08:33 AM
st.evel07
Aug 13, 2015 06:15 PM
