88 iroc 305 tpi switch to 406
I am building a 406sbc with holley weiand stealth mini ram. Afr 210 heads and Howard hydraulic roller cam 286/294 ,533 lift..eagle rotating assembly probably 40 pounds injectors.... what should I do to the computer is what iam wanting to know, chips? Costume tune? I need advice on this build please
Re: 88 iroc 305 tpi switch to 406
Yes you will need a tune.
Even bone stock, it would probably benefit from that, since whatever factory tune you have was for 198x fuel, altitude from sea-level to 14,000', weather from so FL to MN to AZ to WA but you probably don't cover near all those places, etc. etc. etc.
Visit the PROM board on this site; or, consider one of the aftermarket systems; or, consider a modern stock PCM such as a 0411.
Sanjay
Aug 12, 2015 03:41 PM
