2.8 V6 to LS1 swap, Questions
Old Aug 17, 2014 | 08:13 PM
Xtq's Avatar
Xtq
Ive got a 2.8L v6 stock camaro rs im working to convert over to an LS1. ive done a bit of research into what i all need to swap out and change. ive got some questions on what i need to actually swap out and what i can keep.
Can i keep the stock rear end?
Do i need to change the drive shaft?
Someone had said i need to change the torque arm?
I need a recommendation on an automatic transmission to bolt up
Any tips or information are appreciated
Old Aug 17, 2014 | 08:34 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: 2.8 V6 to LS1 swap, Questions
https://www.thirdgen.org/forums/ltx-...third-gen.html should answer all your general questions.
Old Aug 18, 2014 | 10:33 AM
Pocket's Avatar
Car: 91 Trans Am
Can i keep the stock rear end? Yes
Do i need to change the drive shaft? No, rebalancing it cant hurt
Someone had said i need to change the torque arm? No
I need a recommendation on an automatic transmission to bolt up Any 95-07ish 4L60E. Avoid any 3spd auto (TH350/400) and the 700R4. 98-02 V8 Fbody trans is the easiest and most commonly used
Read the swap sticky as posted above, then read it a few more times. There is ALOT required for this swap. Until you know exactly whats required and solve every problem, you should not dive in
Zane Story
Oct 8, 2015 12:40 PM
usafirebird
Sep 29, 2015 11:58 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
89bird2.8
Sep 18, 2015 07:46 PM
