big block wiring harness
Old Sep 9, 2014 | 01:41 AM
couchmotors's Avatar
Car: 1991 camaro rs
Engine: 496 big block
Transmission: th400
Axle/Gears: stock rearend. 3.23
need just a little help. im installing a 496 big block/th400 in my 91 camaro RS. i have removed all the ECM wiring and ECM from the V-6 harness. what wires will i need took reconnect to that clear connector to make the car start there are three wires left that did not go into the ecm on that clear connecter is that for the VATS and fuel pump or will the car still start and fuel pump still work with what i have left. i traced back all the wires the the fuel pump relay and they are still connected and not cut . any help in the matter will be greatly apprecitive thank you
Old Sep 9, 2014 | 11:41 AM
Car: 1991 camaro rs
Transmission: th400
Re: big block wiring harness
Also what do i need to do to wire the speedo back up also what and where does the two black connectors that pluginto the white connector just to the right of the ECM.
Old Sep 11, 2014 | 06:02 PM
Car: 1991 camaro rs
Transmission: th400
On the c207 connector cavity L DK/BLU wire is for the pass-key or vats. With the ecm gone i guess i will have to bypass the vats system at the starter relay in the driver kick panel by grounding the green wire. Only other question i have is for the speedo the red wire cavity P car had a v6 so there is no vss buffer box do i hook up the wires coming from the trans to the red wire ?to get the speedo to work. Can someone out there please help with this.i have read all the post on ls swaps and engine swaps im sure someone can please help with this i would like to drive my car and have everything working correctly. Thanks oscar
Old Sep 12, 2014 | 09:37 PM
Car: 1991 camaro rs
Transmission: th400
lets see if i have this right? connect the wire going from the vss to the gray wire in the c207 connector to make the speedo work and ground the yellow wire and hook the purple wire to the gray wire in c207 connetor for the speedo to work??? or does the yellow wire need a 12 volt source? can someone please answer my question please
Old Sep 13, 2014 | 09:26 AM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
First off, read that. Pics reset mid month
Next, speedo will be a process since the ECM is gone and it was a V6 to start with, plus you're using a cable output trans (TH400). Youll need some sort of electric VSS signal. The cable to electric units from jagsthatrun will do the job nicely. They have a range of outputs available. Next, grab a buffer box from any mid-late 80's Fbody and wire it in like this:
http://www.austinthirdgen.org/mkport...SS_V8_vinE.jpg
FP relay should be independent of the computer, simply move the dk grn/wht wire to an IGN source and the FP will run when the key is on
The red wire on the C207 (wht connector) is VSS to the cruise module
VATS will be disabled in this conversion. The only functioning part remaining is the starter enable relay. If you're using the proper key, this will function normally, if the key doesnt match the VATS module, then dig the relay out of the drivers kick panel and ground the 20ga blk/yel wire
Hooking the VSS wires directly to the speedo will not work
Old Sep 14, 2014 | 09:45 PM
Car: 1991 camaro rs
Transmission: th400
thank you pocket, this helps so much i hope to have my car running soon thank you for all that you do on this site its awsome
Old Sep 14, 2014 | 11:24 PM
Car: 1991 camaro rs
Transmission: th400
so do i get the one that has the output of 4000 pulses per min and run that thru the buffer box and i will be in bussenes yes? i still have the same key so the vats will work fine and thank you for your help
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
