4th gen tank Q's---V6 tank
Subscribe
Sep 11, 2014 | 06:07 AM
Maybe my search phrases weren't right but I couldn't find an answer.
Is there a difference between the V6 tanks and the LS1 tanks? If so what is the difference and is it a problem to use a V6 tank for my LS swap?
there seems to be a lot of V6 tanks for sale.
Reply 0
Sep 11, 2014 | 08:42 AM
Re: 4th gen tank Q's---V6 tank
Depends on what you want your set up to be? The LS plastic tank 99-02 are the same. The difference is in the pump module. The LS V8 Pump module has a regulator in it and the V6 does not.
Read this thread.
https://www.thirdgen.org/forums/ltx-...k-plastic.html
Reply 0
Sep 11, 2014 | 03:11 PM
Thank you.....found out for sure at post 134-5. None of the tanks I've looked at have the pump module anymore. Just wanted to be sure the charcoal canister was the same too.
Reply 0
Subscribe
