350CID Gauges Question
Old Oct 11, 2014 | 11:04 AM
Kuwait_Iroc's Avatar
Car: 1986 Iroc
OK so new issue with my car. I have a 86 Iroc and we have put a 350CID and 700R4 trans in it. I did not realize it at the time but apparently the previous owner put in the dash/gauges from a 91-92 camaro which of course is electronic so I am stuck on the speedo and tach. The rest of the gauges work correctly sense they are not computer controlled. There is no computer in the car so my question is this.....is there any adapters to make the gauges work with a speedo cable? I do not want to drop 600+ on a gauge cluster set for this car. I bought a used cluster set from the 81-89 camaro but it does not match up to the dash so that did not work.
Old Oct 11, 2014 | 01:41 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 350CID Gauges Question
Tach is electric, so run it off the coil or distributor whichever has an output
Electric speedo needs electric VSS, so grab one from a 90-92 car
Old Oct 11, 2014 | 02:10 PM
Car: 1986 Iroc
I thought the signal from the VSS would pass through the ECM and then be sent to the speedo. Is this not correct?
I am not sure how all of that works.
Old Oct 11, 2014 | 03:21 PM
Pocket's Avatar
Car: 91 Trans Am
It goes through a buffer box. Your camaro should already have one. If not, all 86-89 firebird/TAs do along with multiple other cars/trucks
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
