v6 to v8 brake question
Old Nov 7, 2014 | 06:03 PM
camarors2399's Avatar
Ok so I'm putting a 350 in my car from a v6. I'm getting ready to change my mounts and noticed my brake line goes right where my v8 mounts should go. Do I need to move the brake line?
Last edited by camarors2399; Nov 7, 2014 at 09:52 PM. Reason: didnt ask quesrion correctly
Old Nov 8, 2014 | 05:07 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: v6 to v8 brake question
Un bolt the little clamp and pull the whole brake line up. There will be another hole to bolt the brake line clamp into
Old Nov 8, 2014 | 05:56 PM
OK thank you
Old Jan 19, 2015 | 12:48 AM
couchmotors's Avatar
Car: 1991 camaro rs
Engine: 496 big block
Transmission: th400
Axle/Gears: stock rearend. 3.23
i had to do the same thing when i put my 496 bbc in last month. first take the v-6 mounts off, then unbolt the brake line in 4 places then gently bend and move the the line back and use the the same clips and bolts in the new holes i have some pics when i find them i will post them. dont be afraid to use a little elbow greese and move them.
Old Jan 20, 2015 | 05:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
From #12 in the "V6 to V8 Swap" sticky in the top section of this forum:
"The right/front brake line mounts to the front of the crossmember for the V6, right where the V8 mounts need to go. Either use the V8 factory line, or carefully bend the line to the rear of the crossmember after the mounts are removed from the V6 position. The p-clamp mount holes are there for the V8 position for this line."
https://www.thirdgen.org/forums/engi...swap-read.html
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
