t56 cross member and subframe connectors
Old Nov 12, 2014 | 02:03 PM
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Axle/Gears: 3.23 Australian 9 bolt
i collector parts for a t56 swap, and i came across this photo with an x pipe tucked perfectly under the trans mount, with supports coming from either side tieing to the frame connectors. but i havnt seen it for sale anywhere. im assuming that was custom made. but ive seen this pic floating around for awhile, i was wondering if by now someone was producing this as a kit.
Old Nov 12, 2014 | 02:33 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: t56 cross member and subframe connectors
If you included the photo it may help
Old Nov 12, 2014 | 03:00 PM
Alice89's Avatar
I'm curious to see which one your talking about. Do you have the picture saved?
Old Nov 12, 2014 | 06:02 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Is this what you were asking about?
ETA: Belonging to Twin_Turbo is this thread.
Old Nov 12, 2014 | 07:02 PM
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
It's built91z28's car. Obviously he made his himself, mojo that is all I have been able to find, but I like how tight he made his to the car, I'm on my phone right now or I'd post a pic, but honestly idk how from a cell phone,
Old Nov 12, 2014 | 07:13 PM
Alice89's Avatar
I looked up his car; it looks similar to the one hawks sells.
Old Nov 12, 2014 | 07:18 PM
Alice89's Avatar
It's called a "double hump" cross-member. A place called skult used to sell them; but their site has been down for ages.
Here is the next best thing:
http://www.hawksthirdgenparts.com/tr...r-t56-6-speed/
Either the hawks one or building your own will work.
Old Nov 13, 2014 | 02:59 PM
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Thanks for that man, I think I'd be better off just buying square tube steel and having someone make em....along with subframe connectors while I'm at it, does anyone know where to get chromoly steel?
Old Nov 13, 2014 | 06:35 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Mild steel will likely be sufficient for what you are doing.
Also, if you don't know where to get chrome-moly tubing, then you probably don't know how to weld it properly (re-temper after the heat of welder, or something like that). Anyone who will be able to make the cross member and/or SFCs will know where to get it.
Old Nov 14, 2014 | 10:44 AM
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Lolz not at all! Hahah I was considering sourcing material and having a local shop do it for me, but you're probably right, I just don't want the chassis twisting when I'm creeping over storm drains, figured the chromoly parts aren't much more than stainless parts, so why not, but now knowing there's a process to welding it,....that's why not lol
middian
Sep 5, 2015 01:42 AM
Slush92RS
Sep 2, 2015 08:56 PM
tonys91rs
Sep 2, 2015 07:07 PM
