Fuel injected v6 to fuel injected v8
Old Nov 14, 2014 | 06:40 PM
Armada95's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: Chevy 350 HSR TPI
Axle/Gears: 3.23 Open
I have a 91 Camaro rs with the 3.1L v6 port fuel injected, I'm planning on doing a 350 V8 swap in the future, now upon some research and asking some questions at various places, I've come to find out the v6 ECM is actually compatible with the V8 TPI setup. I'm planning on putting Vortec heads on the V8 as well, and I know the aftermarket industry makes a TPI intake for Vortec heads.
My question is, is it actually true? because the 2 ECM's are the same exact part number, do I need to change out the PROM inside it? splice in 2 more injector wires (one for Bank 1 the other for Bank 2 since its group/batch fired) will all the existing sensors still work as well? Or do I need an entire new harness.
Thank you.
Old Nov 14, 2014 | 07:09 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Fuel injected v6 to fuel injected v8
You can easily add two more injectors and add a chip. Loose SD TPI chips are rare, often only had with the ECM which is basically worthless because of how common V6 ECMs are
Dont forget to rearrange the accessory connectors for the V8 serp setup
If you want a complete assembly I have a 305 TPI pullout from my 91 TA for $500. Swap a 350 long block in and use the rest. Harness/ECM, exhaust, fuel lines if you want them
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
86Base
Aug 13, 2015 05:06 PM
