Fuel Injection to Carb
Old Dec 23, 2014 | 08:49 PM
hartsmike's Avatar
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
For those who have gone from TPI or fuel injection to carb did you have to run new fuel lines to fuel pump on front of block or how did you do it?
Old Dec 23, 2014 | 10:14 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Fuel Injection to Carb
2 ways of doing it. You keep your stock fuel lines with both.
You can keep and use the stock in the tank elec fuel pump, install a mallory $90 fuel pressure reg. on the supply line under the hood, adjust pressure down to 5-6 psi, and just leave mech. pump un hooked, or remove it and put on a block off plate.
Or you can....
Remove fuel tank pickup/sender/pump and replace the pump with a length of fuel line , compression fittings or rubber/hose clamp...... Or replace the whole sender/pickup with a new one from a non EFI third gen.
Then just hook your fuel line up to the block mounted mech. pump (you will have to add some line to reach to the pump)
Old Dec 24, 2014 | 08:57 AM
hartsmike's Avatar
Axle/Gears: 273
Thanks Rider.. So the lines will hook right into the carb then?
Old Jan 4, 2015 | 10:21 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Yea. Once you're out of the regulator you should be at 5-6 ish psi. So you can use rubber and hook it up. Also I believe all of the wires that come from passenger fender are able to be removed to clean things up.
Old Jan 4, 2015 | 10:46 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
both are correct.
i am using the stock tbi fuel pump to fed my regulator which goes to my holley. i used rubber lines from the stock fuel lines to the regulator and to the carb.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
86Base
Aug 13, 2015 05:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
