305/350 swap problems
Old Jan 5, 2015 | 03:07 PM
FBODYTOOLBAG's Avatar
thanks for your tip. fuel pump is fairly new, however I have seen high volume pumps on the market for this application. just another quick question. I have also had to block off the fuel return line. If I keep the return line unblocked, the car will not run at all. if I block it off, fuel pressure jumps to 11psi. I have not altered anything with the fuel system, its all still stock. so why would my return line need to be blocked? other than fuel pump just not putting out enough to keep it running? I also noticed on the 350TBI set up on the trucks, do not have this return line at all. any advice on this as well? thanks. much appreciated.
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
