87 350tpi in 85 305tpi out
Old Jan 26, 2015 | 09:57 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I'm snaged.this 85 z28 was a factory LB9.Harness is still in. have a L98 from the yard with the harness cut to take it out. Most everything matches. My snag is the dizzy. One of or members said to change the gear on the bottom because the l98 was roller cam. the stock motor was long gone by the way! I got a dizzy from ame yard,coil in cap type out of a carb 305.the gear looks like the one on a 91 tbi 305 I got. Thats suppose to be a roller cam to I think. I've removed both gears and the iner diamiter is larger on the carb gear but the outer and gear angles look to be the same. the wiring is set up a little different from one to the other. help me through this guys!
Old Jan 27, 2015 | 05:16 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 87 350tpi in 85 305tpi out
nobody? I went and got the ecm that was in the car I got the motor out of.
Old Jan 27, 2015 | 06:39 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Iirc you can just swap the gear and be all set. Or rewire the harness for the small cap distributor. Believe its pretty similar coloring.
Old Feb 19, 2015 | 06:09 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Here is some info from the Chevythunder website.
http://chevythunder.com/fuel%20injec....%20pg%20A.htm
86iroczwv
Sep 3, 2015 06:21 PM
jbd1969
Aug 17, 2015 07:06 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
rdog30
Apr 6, 2001 07:07 PM
Stell1579
Aftermarket Product Review
Oct 11, 2000 10:47 PM
