Hamonic Balancer Size
Old Feb 28, 2015 | 01:16 PM
mcweens's Avatar
Car: 1987 IROC-Z & 1991 RS
Engine: IROC-305tpi & RS-357(built)
Transmission: Both-700R4
Axle/Gears: IROC-3.23 & RS-4.10
I'm currently in the process of buying parts for a 406 small block build for a 1987 IROC, street/strip car. I am currently looking for an internally-balanced harmonic damper. I have been looking at either ATI #917780 or #917781. The only difference with these two dampers is the size: One is 6.35" and the other is around 7" (also the 7" is about $30 more). I was wondering if I should spring for the 7", or if it wouldn't be any better than the 6.35". Max RPM on the motor will be between 6500-7000. Any help is appreciated.
Old Mar 11, 2015 | 04:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
So you're having the 400 crank internally balanced?
I would go with the larger damper. It will more effectively dampen harmonics, and won't contribute significantly to rotating momentum.
Any other details of your build you'd like to share? Like heads, rods, induction, etc.
Old Mar 15, 2015 | 06:35 PM
mcweens's Avatar
Re: Hamonic Balancer Size
It's a Scat forged crank, so yes it is internally balanced. Block is a 1976 but it's splayed, 6" forged i-beam Rods, Forged aluminum dished pistons, AFR 220cc heads, compression around 10.1:1, naturally aspirated.
Old Mar 16, 2015 | 11:30 AM
mcweens's Avatar
I've got another question. ATI makes two different 7" balancers: one is 8.75 lbs and the other weights 6.25 lbs. I know the more the balancer weighs, the better it dampens engine harmonics at high RPMs... but for a street/strip 406 @ 7000 RPMs, is 8.75 lbs a little much? Would it make more sense to get the lighter one and gain horsepower that way?
PurelyPMD
May 5, 2016 04:57 PM
Nervous2
Oct 8, 2015 10:53 PM
Linson
Sep 21, 2015 01:08 PM
Magman
Sep 13, 2015 12:14 AM
m00n420
Sep 11, 2015 02:39 PM
