l31 swap starter problem
Old Jun 1, 2015 | 05:34 PM
firehawks's Avatar
Car: 1989 Firebird, And soon 1989 Iroc
Engine: Firebird 5.0, Iroc vortec 350
Hello
im in the process of doing the l31 swap in my 89 camaro and have run into a problem with the starter. The stock starter don't seem to fit. Do i need to use something different? Do i need a different flex plate and starter. Im lost, could anyone help shed some light on this..
Old Jun 4, 2015 | 01:30 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: l31 swap starter problem
they used the larger ring gear flexplate in the trucks, so you need a starter for the larger ring gear... or if you still have the flexplate off your stock engine, you could put that on the new engine and use your stock starter.
Old Jun 11, 2015 | 11:51 AM
mizz0313's Avatar
Car: 92 Camaro RS Heritage Edition PoloG
Engine: L31 Vortec
Transmission: 4160e
Axle/Gears: 4th Gen Torsion Rear/ 3.42s
did the same swap and i used flexplate from truck i believe its 168 tooth plate, anyways i bought a mini starter from amazon and it fits fine in my 92 camaro. if you need any help finding one let me know but just search it on amazon youll find it
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
