Dyno results
Old Dec 18, 2001 | 09:14 AM
Z28DJP1987's Avatar
Dyno results
Dyno results after engine swap to 350 TPI
Old Dec 25, 2001 | 09:18 PM
TTA's Avatar
TTA
Cool almost Stock LS1 area
Old Dec 29, 2001 | 08:13 PM
c-5invalid's Avatar
have you taken it to the track?
Old Dec 29, 2001 | 08:26 PM
Z28DJP1987's Avatar
No I have not run the car at a track. But it is a strong street car with nice Torque at 3300 RPM's.
Old Dec 31, 2001 | 01:24 AM
rezinn's Avatar
Stock LS1 territory? Im seeing 210hp and 280ft/lbs.. Stock LS1 is around 290-300hp 295-305ft/lbs at the rear wheels. Stock L98s made at best 200rwhp and 280ft/lbs, so it looks like you're doing a bit better. Mid 14s I'd say.
Edit.. Get new rear end gears! =)
Old Jan 3, 2002 | 01:01 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Nice numbers. I bet the rwhp and rwtq would be even better with less restrictive intake track.
FWIW:
Stock LT1's are in the 240-260 rwhp , 280-295 rwtq range
Stock LS1's are in the 280-310 rwhp, 290-320 rwtq range
The 01-02 LS1 cars tend to be the highest stock.
Old Jan 3, 2002 | 04:08 PM
Z28DJP1987's Avatar
91 RS
May be the numbers COULD HAVE or SHOULD HAVE been
better. But I did not install every part someone said I SHOULD
Have. This engine is up and running with a Dyno Chart to prove its numbers and not like most of the Posts. Anyways thanks for your comment on the numbers.
Falcon50
Aug 22, 2020 03:26 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
