305 to 350/383 TPI swap what can I re-use?
Old Jan 3, 2002 | 01:45 PM
87GTA OO's Avatar
I'm wanting to swap my perfectly good 305TPI for a 350/383 in my '87 GTA.
1) What can I reuse from my 305 TPI?
2) What is a 305 motor with about 3K miles on it worth? It's not the original block.
Old Jan 3, 2002 | 04:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What you CAN use and what you SHOULD use are two different things.
You CAN use it all.
You SHOULD get higher flowing components for the 383 at least - base, runners, plenum, TB, injectors, and an AFPR to tune it. Exhaust upgrades should be considered a given.
The 350 will work with the 305 stuff, but even 305's gain from increased flow. AFPR always a good idea.
Customized PROM also a good idea.
You should be able to get at least $500 out of a sound 305.
xkingcodex
Feb 12, 2020 07:43 PM
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
