383 stroker swap TBI/Injector question
Old Jun 16, 2015 | 09:45 AM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
I've got a 92 RS 305. Thinking about doing a 383 stroker swap. I'm looking to use the stock TBI unit, however I wasn't sure what or if I needed to replace the stock injectors for higher lb/hr ones? Also are there any recommendations as to in intake for this also?
Old Jun 16, 2015 | 10:25 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 383 stroker swap TBI/Injector question
The stock TBI unit and injectors barely flow enough to handle a stock 305 or 350. A 383 is way too much, a TBI cannot support the airflow or fuel requirements. You need to upgrade to a multi-port fuel injection setup to support a 383.
They make 4-injector pods for a TBI, which is better.
Old Jun 17, 2015 | 06:40 AM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Gotcha. After I posted this I started reading the sticky's about these swaps and TBI changes and the like. Thank you for replying.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
