88 firebird 2.8 to camaro 5.0
Old Jun 24, 2015 | 10:47 PM
1988_f-bird's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 carburated
Ive been working on this project for a while and now its down to the final fight. It will start, when it tries to idle down after it starts, it quits. If i feather it, it misses terrible then when i per off the gas it will die. If i floor it it will die. I put new injectors and idle control valve on but no change. Please help.
Old Jun 28, 2015 | 08:55 PM
ex-x-fire's Avatar
Re: 88 firebird 2.8 to camaro 5.0
So what did you swap over to? Tpi or tbi? Did you use a matching harness & ecm?
Check fuel pressure. Did you set the throttle postion sensor?
Old Jun 29, 2015 | 03:43 PM
I swapped to the the throttle body, two injectors, how do you adjust the throttle position sensor? I think it might be the fuel pump. The last motor was tune port and this one is throttle body so i think the tune port had a lot more pressure. Any ideas on that?
Old Jul 3, 2015 | 09:36 PM
Alright. I put new sebding unit and correct fuel pump in. Its still doing the same thing! What else is there. Could it be sonething with the fuel canister? Any sensors that might tell it to quit? Is the computer junk? Please help
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
colton_carlson
Mar 8, 2019 12:21 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Randomtask2
Aug 13, 2015 01:57 AM
