Supercharged or turbod 418
Old Jul 25, 2015 | 01:02 PM
Powellbr's Avatar
Hey all, first off this is my first post on here, and was wondering IYO if I should go with a Turbo or a supercharger because I'm going to be swapping the stock TPI engine with a newer 418 LS3. I'd like to know what you think that way I have all my ducks in a row before I get started. Thanks in advance for the information in advance.
Old Jul 25, 2015 | 01:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Supercharged or turbod 418
Nothing scream HP like a supercharger poking out of the hood but when you look at modern cars, especially LS powered cars, turbos is the way to go. Each system has advantages and disadvantages. It's up to you to decide which way to go.
Old Jul 25, 2015 | 01:28 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Welcome. As Alky mentioned, Its up to you on what way you go. There seems to be more turbos going in LS here at 3rd gen. Both have there pros and cons. There is a ton of info here from what Ive read about putting in a turbo.... So maybe a super charger is the way to go? I think NufNuff has a SC in one of his.... Either way, exciting build! You going to start a build thread here?
Old Jul 25, 2015 | 02:31 PM
Powellbr's Avatar
I might once I start working, I've got my eye on a 3rd Gen over in grand junction, but unfortunately I haven't been to work lately, although with my luck by the time I can buy it someone else will've bought it
Old Jul 25, 2015 | 04:45 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Supercharger for me, originally I was going to buy a crate 572 and put a F2 procharger on it, procharger stated it would make about 1400hp
Old Jul 25, 2015 | 04:58 PM
Powellbr's Avatar
So that got me thinking, with my other build, I'm gonna be going to be using a LSX 427 with a Whipple supercharger with a 19 psi pulley and a water/Meth system with a ntiro additive, I've estimated that I'm gonna be making around 1800 horsepower and people are saying that I'm not gonna be making that. What do you think?
Old Jul 26, 2015 | 12:18 AM
AlkyIROC's Avatar
Car: 87 IROC L98
So do your research and build it to prove them wrong. Don't forget to document the build on TGO.
You might as well scrap the production car and start with a tube chassis car if you plan on making that much power. The engine will be the least of your worries.
Old Jul 26, 2015 | 12:50 AM
Powellbr's Avatar
This isn't with a third Gen, it's with a fifth Gen Camaro, which from I've read has a lot stronger body and chassis than a third Gen
Old Jul 27, 2015 | 09:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
It's still a unibody and tube chassis is the way to go at that power level.
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
