v6 to v8 motor mount help
Old Sep 11, 2015 | 12:29 PM
92projectcamaro's Avatar
Car: 1989 rs coupe
Engine: 2.8 turbo build
Axle/Gears: 3.27 posi
ik a lot of u guys have done this swap before can someone tel me the best and most efficient way to remove the motor mounts from the k member and so I can move them up
THANKS!!!
Old Sep 11, 2015 | 01:00 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: v6 to v8 motor mount help
You'll need two people unless you are small. I used a wrench to get to the bolts from the opening where the A-Arm is, and had my Dad use my impact on the nuts on the outside.
You will need V8 mounts as the V6 mounts are different from the V8 ones.
Old Sep 11, 2015 | 01:44 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
After dropping the socket into the frame, I just took off the control arms and used that time to get new bushings lol. Something to think about.
Old Sep 11, 2015 | 03:22 PM
Car: 1989 rs coupe
Thanks guy and rubbber ducky my mounts will work the motor Is from the same exact car and 92 v6. That is is getting a 92 v8 everyone I takes to it all fits together they just have to be moved forward
Old Sep 11, 2015 | 04:51 PM
Night rider327's Avatar
Car: 1988 Camaro
V8 mounts are NOT the same as the V6 mounts... End of story.
I have done atleast 15 V6 to V8 swaps on these cars over the years. My own 1988 camaro was a V6 car, now a V8.
You need the V8 steel clam shells for the engine
And you need the V8 rubber engine mounts for K member
You also need to move the placement of the V8 mount on the K member.
Old Sep 11, 2015 | 05:07 PM
Car: 1989 rs coupe
Thats why I'm asking how to remove old ones
Old Sep 11, 2015 | 05:19 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
From what I recall there are access holes in the K-Member that can help if you have the right wrenches to take advantage of them. That said, the angles from the holes to the nuts may be different as mine was for a V8. I think too that the nuts will fall into the K-Member if you're not careful.
Old Sep 12, 2015 | 12:33 AM
Car: 1988 Camaro
You can take off the A arms which makes it easier...
Or you can fight with extensions, wobble/u joints, and wrenches
The 1st few I did, I went with the ladder of the two. Since then I just started dropping the A arms.
The engine mount bolts/nuts are 15mm. I took an old cheap wrench and bent the boxed end part to about a 35* angle or so to help get up through the access holes and to the nuts
Use small dia. rare earth magnets in your socket to hold nut in place...
Use heavy wheel bearing grease in your wrench box end to help hold nut in place.
Even pack your U joint/wobble joint with grease so it's stiffer.
The combo of my bent wrench, 3/8" drive extensions in diff lengths, a couple of U joints and diff length sockets worked
You can go in from the round drilled access holes in K member and also the gap between the A arm and K member.. On the back side of K member, reaching kinda through the spring a little
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
