305 to 350 swap
Old Oct 15, 2015 | 11:06 PM
transamaster's Avatar
Car: 1989 Trans Am
Transmission: 700 R4
305 to 350 swap
I have an 89 trans am that came with the 305, I was wondering what I would need to do to drop a carbureted 350 Chevy into it, I already have the 700r4 trans. Thanks
Old Oct 16, 2015 | 03:33 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Re: Pontiac V8 Swaps
The motor will drop right and bolt to the tranny and exhaust. If you want to retain the computer, you'll need to do some work. If you want to run a wire to the distributor, and cable to the throttle lever, and bypass the computer, it'll be easier. Not sure about the electrical to your tranny, IE loc-up converter and such.
Old Oct 21, 2015 | 03:04 AM
d3v1l8oy's Avatar
Car: 89 camaro
Engine: 5.7, 350
Re: 305 to 350 swap
I actually did this swap a long time ago in my 89 camaro rs I had the 305 TBI and I built an old 350 I had laying around I used heads from a truck and used the same manifold and TBI bolted to my bellhousing, exhaust and used same engine mounting points even used same computer car ran great no issues till I drove it to hard and blew up the tranny. I was curious tho are u switching from TBI to carb? Also why are u making the switch to carb? If it's because of fuel you can find upgraded fuel injectors and fuel pump to match fuel needs no problem.
69GTOby
Apr 18, 2016 02:34 PM
BLK87Z
Sep 18, 2015 11:29 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Formula_88AE
Sep 3, 2015 01:47 PM
