anyone try the holley systemax system yet?
Old Dec 20, 2001 | 10:39 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
just want to know what they are like from the ones that use it
Old Dec 21, 2001 | 03:37 PM
MotorCityMuscle's Avatar
The Systemax consists of heads, valvetrain, cam right?
Ive never used the heads, but a friend did and he seems satisfied. The cam seems to be an old style single pattern grind, IIRC. You'd be better off going with one of the CompCams XE series instead. Im guessing your asking about using this on a 350 or 383 you've talked about building? If your asking about using it on a 305, I wouldn't do it. That cam's a bit much for a street 305 and the heads will put your CR in the toilet. You actually need more compression with aluminum heads due to extra heat loss.
Which motor are you asking about befor I type anymore?
Old Dec 22, 2001 | 12:09 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
definately a 350 or a 355
Old Dec 22, 2001 | 12:16 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
http://www.holley.com/HiOctn/ProdLin...K/300-503.html
check out this site
this has all the details on the system and all that fun stuff
Old Dec 22, 2001 | 11:34 AM
I stand corrected about the cam specs. It looks to me like a pretty good performance grind, probably will lope a little at idle but shouldn't be too bad with the fast bleed lifters. I think you can count on ditching the computer, so find a new carb and distributor too. I would call their tech suppoort and ask how that cam will do with a stock torque converter, and if it will affect power accessories. You'll also want to run headers. Your gas mileage will probably suffer too.
Just some stuff to consider before you spend your money I guess. I got my first firebird when I was 17 and i built an engine a lot like the one your describing and drove it everyday. I spent a ton on gas, and couldn't drive around town in traffic much because i lost a lot of my low-end. i also spent a lot of cash on upgrading the rest of the car to match the drivetrain. i had to work my *** off all summer to pay for the stuff and only got to the strip twice. In the end I would have been better off just driving the car and enjoying it and upgrading slowly. have fun in whatever you choose to do.
Old Dec 23, 2001 | 12:20 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well i already plan on junkin the computer and the smog stuff and i am gonna have to use the stock drivetrain until i have enough money after the motor build for the upgrading
and hey im 16 now and will b 17 when i do this swap
weird eh?
i prolly wont break anything cuz my bro said i wont get anytraction to b able to
lol
but thats fine with me
i just want to b able to smoke them really good and then do some half throttle racing against ricers and other cars!
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Magman
Sep 14, 2015 01:30 AM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
